How can I open an ESRI .style file?
  • Aug 20, 2020 8:16 AM UTC
  • 194 views
I downloaded some soil data from here. Included in the data is an ESRI shapefile and a .style file, which I can open in ArcMap to style my layer. However, I can't figure out how to open this file in FME. There doesn't seem to be the right format in the reader. Since I want to do this multiple times, I want to figure out how to automate the styling progress with FME to let's say create a kml-file with the correct styling in the end. Is there a way to open this file in FME?
Forum|alt.badge.img+63
It's a proprietary binary format so unfortunately the answer is no, you can't use this in FME.
This means that if you want to automatically style a KML you'll have to set that whole process up yourself.
  • Aug 20, 2020 8:58 AM UTC
Thanks for the reply. Are ESRI .styles in general proprietary or is it just from this specific source?
Because if it is the .style format in general I would imagine there is a bigger use-case for my issue...
I think it's ESRI-specific and would be surprised if they'd open that up (vendor lock-in).
