How can I migrate Intergraph Warehouse data to Oracle Spatial Object with FME ?
  • November 21, 2012
  • 7 views
Can you have a Step by Step manual that explains How can I migrate data (Intergraph Geomedia Warehouses) using FME to Oracle database (Oracle Spatial Object) ? Remember that Intergraph use GOOM Package for storage on Oracle. Have FME an alternative ?
I appreciate your valious time.
Regards,
Iturbides
  • November 22, 2012
Hi Iturbides,
Is your Intergraph Warehouse Oracle based?  I think you just connect to the source data with the Oracle Spatial Object reader.
The Intergraph readers are only used for Access or SQL Server based warehouses.
You can just use File > New > Generate workspace...
Or even the Genereate workspace using wizard option to create the transformation.
Let me know if this works for you.
Annette
fmelizard
Forum|alt.badge.img+19
  • November 22, 2012
Hi Iturbides
I'm going to make a support case on this for you. You'll get an email from support shortly.
Thanks
Ken
