How can I merge SHP-files with the same names from several subdirectories, into single files?
  • Feb 10, 2021 11:17 AM UTC
  • 99 views
jonas_nelson
Forum|alt.badge.img+34
I have almost 100 subdirectories, each with shapefiles of the same names, eg:
/dir1/FileA.shp
/dir1/FileB.shp
/dir2/FileA.shp
/dir2/FileB.shp
/dir99/FileA.shp
/dir99/FileB.shp
Not only are there almost 100 directories, there are also about 30 shapefiles in each.
Is there a smart way to get an FME workbench to read all these subdirectories (they are all stored under a common "mother directory") and files, so that I can merge them into one Shapefile each?
What I want is to merge all FileA.shp into one file, all FileB.shp, into another, and so on.
Best answer by ebygomm
You can use a featurereader to read all shape files within a certain parent directory if you set the dataset path to something like
C:\ParentFolder\**\*.shp
You can then use the schema to dynamically write out to shape files, one per featuretype (filename)
Forum|alt.badge.img+54
  • Feb 10, 2021 11:33 AM UTC
jonas_nelson
  • Feb 10, 2021 1:08 PM UTC
Thanks @ebygomm​ , that made my day a LOT easier - just like FME should. 😃
(Not sure that I did it by the book, but it works):
Skärmklipp_FME
hkingsbury
Forum|alt.badge.img+73
  • Feb 10, 2021 9:13 PM UTC
Skärmklipp_FME
nice! A good solution to this problem would to build a dynamic workflow. That way, if new (named) shapefiles are added, then you don't need to import new feature classes on your reader or create new ones on your writer
https://community.safe.com/s/article/dynamic-workflow-tutorial-introduction
