How can I make MapboxStyler for polygon file?
  • Apr 4, 2024 8:42 AM UTC
  • 94 views
hoa_le
I have a polygon file. I want to make MapboxStyler for it. But I don’t see it styled.
I use parameters as the below:
Could you tell me why? Thank you
saraatsafe
Forum|alt.badge.img+13
  • Apr 8, 2024 8:30 PM UTC
Hi @hoa_le, what format is your input data in and how many polygon features are you reading in? Have you run into this issue with other polygon files or is this the only one causing trouble?
hoa_le
  • Apr 9, 2024 1:57 AM UTC
Hi @saraatsafe , the format’s .Shp and 200,000 polygon
saraatsafe
  • Apr 11, 2024 9:42 PM UTC
Hi @hoa_le, would you be able to save your workspace as a template and attach it here? I haven’t been able to recreate your issue. You can save your workspace as a template by running with Feature Caching enabled, and then going to File > Save as Template and checking off the Include Feature Caches checkbox. Let me know if you have any questions!
