How can I get the elevation from ASCII to a 2D vector point
  • Jun 3, 2020 2:29 PM UTC
  • 95 views
pauledrummond
Hi.
I have LiDAR data in .asc and .las formats. I also have .shp file points that I would like to attach the elevation from the LiDAR. How would I go about this?
Any help wold be much appreciated.
Paul
Best answer by jdh
You can use a SurfaceDraper with your point cloud going to the Points/Lines port and your shapefile points going to the DrapeFeatures port.
The benefit to this method is that the point features don't need to correspond exactly to an element in the point cloud.
danilo_fme
Forum|alt.badge.img+58
  • Jun 3, 2020 3:50 PM UTC
Hi @pauledrummond
I suggest you to use the transformer PointCloudCoercer -> CoordinateExtractor -> SpatialFilter:
Thanks in Advance,
Danilo
jdh
Forum|alt.badge.img+41
  • Jun 3, 2020 4:18 PM UTC
pauledrummond
  • Jun 4, 2020 6:00 AM UTC
Thanks to @jdh @danilo_fme for your responses.
I ran both solutions and found JLD's solution to be much faster.
Much appreciated. @pauledrummond
