How can i extract data from this line?
nick3_s75
{"sl:stand": {"sl-bag-extract:bagObject": {"Objecten:Pand": {"Objecten:status": "Pand in gebruik", "Objecten:geometrie": {"gml:Polygon": {"@srsName": "urn:ogc:def:crs:EPSG::28992", "gml:exterior": {"gml:LinearRing": {"gml:posList": {"#text": "114062.419 542728.035 0.0 114067.343 542726.792 0.0 114067.637 542728.082 0.0 114068.445 542728.468 0.0 114069.011 542730.438 0.0 114068.36 542731.246 0.0 114068.639 542732.471 0.0 114063.762 542733.793 0.0 114064.204 542735.512 0.0 114057.619 542737.161 0.0 114055.721 542729.372 0.0 114055.572 542729.428 0.0 114053.081 542719.589 0.0 114059.937 542717.727 0.0 114062.353 542727.763 0.0 114062.419 542728.035 0.0", "@count": "16"}}}, "@srsDimension": "3"}}, "Objecten:voorkomen": {"Historie:Voorkomen": {"Historie:BeschikbaarLV": {"Historie:tijdstipRegistratieLV": "2010-11-26T12:31:16.436", "Historie:tijdstipEindRegistratieLV": "2014-10-27T12:32:20.904"}, "Historie:eindGeldigheid": "2014-09-25", "Historie:beginGeldigheid": "1930-10-17", "Historie:eindRegistratie": "2014-10-27T12:00:33.000", "Historie:tijdstipRegistratie": "2010-11-26T12:11:13.000", "Historie:voorkomenidentificatie": "1"}}, "Objecten:documentdatum": "1930-10-17", "Objecten:geconstateerd": "N", "Objecten:identificatie": {"#text": "0366100000006739", "@domein": "NL.IMBAG.Pand"}, "Objecten:documentnummer": "BV 100", "Objecten:oorspronkelijkBouwjaar": "1935"}}}}
Best answer by nielsgerrits
Attached sample workspace.
nielsgerrits
Forum|alt.badge.img+54
It depends on what info you want exactly.
Transformers generally used for JSON extracting:
  • JSONExtractor
    • Extract specific portions to attributes.
  • JSONFlattener
    • Flattens objects, extracting keys and values to attributes. You will need to expose these attributes as they are unexposed.
  • JSONFragmenter
    • Extract specific portions to features.
  • May 13, 2025
Try a JSONExtractor followed by a JSONFlattener:
Remember to expose the attributes you need in the JSONFlattener.
nick3_s75
  • May 14, 2025
Thanks for the help, i'm still don't get there.
nielsgerrits
  • May 14, 2025
Forum|alt.badge.img+49
One quick remark: FME is case sensitive when it comes to attribute names. So you have set Objecten_pand in the JSONExtractor but then refer to Objecten_Pand in the JSONFlattener
danilo_fme
Forum|alt.badge.img+45
  • May 14, 2025
Great job
nick3_s75
  • May 15, 2025
Tanks everybody
