Hi, Does anyone know how to extract the Creation Date of an IFC file?
  • Jun 22, 2021 9:00 AM UTC
  • 261 views
I'm trying to extract the Creation Date of an IFC file.
It is usually located under IfcProject in viewers like Solibri, but I can't seem to find it.
I want to read a folder containing a bunch of IFC files, and create a list of when the files were last created.
IFC Creation Date SolibriIFC Creation Date
Best answer by chrisatsafe
Hi @j.sveinson​ ,
Similar to opening the IFC in a text editor, you can read in the IFC with a text file reader and parse the header info everything after Creation Date until the next line.
I did a quick test with a few IFC's I had lying around and although the header info was formatted differently, it worked just fine. 2021-06-24_15-43-45In your example, you could follow similar logic but instead of using an AttributeSplitter, you could simply use a SubstringReplacer and AttributeTrimmer to get the desired value after reading the IFC as text, and filtering for the feature that begins with "Creation Date:"
2021-06-24_15-50-14
Hope that helps.
chrisatsafe
  • Jun 24, 2021 10:51 PM UTC
Hi @j.sveinson​ ,
2021-06-24_15-50-14
Hope that helps.
  • Jun 25, 2021 6:44 AM UTC
Thanks alot!
I think this will be a good solution for my use case! 😀
  • Jul 8, 2021 6:35 AM UTC
A colleague of mine found another solution:
IFC Creation Date
