Hello everyone, I want to change the name of the shape file to "asd.shp" rather than "Table1". I need a solution suggestion for this. Also, I don't want to see all the columns in the excel list in my shape file, I need some of them.
  • May 3, 2021
  • 7 views
Best answer by redgeographics
I'm assuming you're using the FME Workbench to set up the translation rather than the Quick Translator.
If you open the properties of the output feature type you can change the name of the output shapefile:
Screenshot 2021-05-03 at 10.34.20Next, in the User Attributes tab, you can remove attributes if necessary
Screenshot 2021-05-03 at 10.34.29
Forum|alt.badge.img+49
  • May 3, 2021
