Has anyone tried to write to an In-Memory table such as a PostGIS temporary table?
  • Oct 18, 2019 1:58 PM UTC
  • 184 views
mark2atsafe
Forum|alt.badge.img+59
For what it's worth, I've tried this in a SQLExecutor transformer before, like...
FME_SQL_DELIMITER ;
DROP TABLE imark_temp_table;
CREATE TEMPORARY TABLE imark_temp_table (a varchar(100),b varchar(100));
INSERT INTO imark_temp_table (a,b) values ('xxxx','yyyy');
SELECT COUNT(*) AS FeatureCount FROM imark_temp_table;
But it only exists during that SQLExecutor. If I tack another SQLExecutor on afterwards and repeat the SELECT COUNT(*) command, it tells me imark_temp_table doesn't exist.
So I guess it works, but I'd say the uses are fairly limited.
  • Oct 28, 2019 4:27 PM UTC
I gathered that postgresql temporary tables are created in the buffer. So, I wonder whether the use of temporary tables can help speed up the process.
Any clue?
