Has anyone experimented with connecting to "Databricks on AWS" data sources? If so, which reader format or transformer should be used to make the connection and browse the available data?
  • Sep 16, 2022 7:07 PM UTC
  • 368 views
pmcpherson
Forum|alt.badge.img+11
JennaKAtSafe
Forum|alt.badge.img+9
Hi @pmcpherson​, At this time we do not have a Databricks Reader/Writer.
As a workaround you could use the JDBC Reader/Writer and by installing the Databricks JDBC Driver (/FME/plugins/java in My Documents) and then restarting FME, you would be able to see if you can connect to the Databricks Database. However, I do believe you would need to use SQLExecuter to interact with Databricks using 'SQL' like commands to pass to the Databricks Database. Let me know how this works for you.
pmcpherson
  • Sep 23, 2022 11:38 AM UTC
Jenna,
Thanks for the response. Yes, after I posted this question I eventually found the JDBC option and was able to install the needed driver and query data (and browse the tables) using the SQLExecutor.
