hai.my reader was 5 .las files.i want to create a outer polygon for the .las.it will created but that is only one polygon.i need to create a each .las each polygon for my writer.
Enable the format attribute "fme_basename" from first to last step in your workbench and use fanout option based on fme_basename attribute. You will get 5 files as output with the same name as input file name.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
