Getting numbers out of cells with text and producing a list with all these numbers
I have a column given to me in a spreadsheet which looks like that:
What I need is to get all the references out, the ones in square brackets, to provide with the full list to a user:
An then get a full list of all references, as follows:
Does anyone have an idea of how I can do this using FME?
  • October 25, 2016
referencesfinder.fmwtGiven an input attribute "text", this sequence of transformers will give you one feature per reference with the attribute "Reference_item" containing a reference number.
You could then consider using a DuplicateFilter (DuplicateRemover before FME 2016) and/or a Sorter before proceeding.
Sample workspace is attached.
Forum|alt.badge.img+40
  • October 25, 2016
A stringsearcher with regex such as [0-9]{4} (this assumes they are always 4 digits) to build a list of matched characters, then a list exploder to create the separate features
  • October 25, 2016
But you'd also end up with numbers outside of the brackets, if there are any...
  • October 25, 2016
Yes, does depend on how sure of the data format you are
gio
Forum|alt.badge.img+15
  • October 25, 2016
@darius
Connect the spreadsheet to a SQL-Executor. (i used a texfile here)
Then Create following script.
It creates attributes from all hits of a regular expression.( By assigning them levels)
The purple bits you can edit as you wish/need.
A shame the InlineQuerier does nto recognise regexp_substr etc.. Then yu would not need a database connection for this. AS we simple use dual here.
gio
  • October 25, 2016
into attributes.. (i created random text and random typed numbers after the first couple b.t.w.)
@darius
  • October 26, 2016
gio wrote:
@darius
That's a cool solution. Just be aware, as for the other one, that this will also return any numbers occurring outside of the bracketed list.
  • October 26, 2016
Thanks for this doing this so throughly. It worked really well!
  • October 26, 2016
Not sure if there are numbers outside the square brackets. The spreadsheet is quite large, so numbers that are not references will be extracted. References are always in square brackets. However, I will use the regex expression from @david_r, which works very well.
  • October 26, 2016
gio wrote:
@darius
Thanks gio. As @david_r said, this is a clever solution. However, I am not sure if numbers ocurr outside the square brackets.
gio
  • October 26, 2016
@darius
Of course, it would. This is just to show the technique.
It is not to show how to create regular expressions.
And example text posted does not show any numbers outside brackets.
Anywaýs':
(?=[;\\[]*)\\b\\d+\\b(?=[;\\]])
all numbers between brackets and or semicolons.
  • October 26, 2016
gio wrote:
@darius
Anywaýs':
This regex would also work within the stringsearcher
