Getting fatal error while DGN to DWG
  • November 16, 2017
  • 36 views
kindly help me convert from DGN to DWG file.
I'm following this procedure:
Right click on dgn file -> translate with FME quick translator
reader - dataset: I browse the dgn file
format: automatically recognized to Bentley Map XFM design V8
writer
Format: I select Autodesk AutoCAD DWG/DXF
click on OK
output:
DESIGN READER: Opening DGN V8 file 'C:\\00 Enrique\\02 Desarrollo Negocio\\Países\\Suecia\\00 E4 Bypass\\FSE901\\Original\\Export\\001D_FU\\004D_5 Tekniska handlingar\\001D_Samordningsmodeller och beskri\\I100K110\\I100K110-01.i.dgn'
DESIGN READER: Error opening Design file C:\\00 Enrique\\02 Desarrollo Negocio\\Países\\Suecia\\00 E4 Bypass\\FSE901\\Original\\Export\\001D_FU\\004D_5 Tekniska handlingar\\001D_Samordningsmodeller och beskri\\I100K110\\I100K110-01.i.dgn
Failed to obtain any schemas from reader 'DGNV8XFM' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
FME Session Duration: 1.3 seconds. (CPU: 0.6s user, 0.6s system
thanks!
erik_jan
Forum|alt.badge.img+20
  • November 16, 2017
Is it actually a DGN XFM file or a regular DGN V8 file?
So, is it the right reader format or should you pick another?
thanks for answering Erik.
how can I know which reader is the adequate??
I so far tried with:
bentley microstation design V8
bentley map xfm design v8
bentley microstation design v7
and all of them failed.
is there any way I can share this dgn file with you, so that you might try to open it?
thanks so much Erik
erik_jan
  • November 17, 2017
thanks so much Erik
If the file is not too big, you can attach it to this question and I will have a look.
i100k910-01overlay.dgn
i100k920-01overlay.dgn
thanks for the help @erik_jan
I'm attaching a couple dgn files, please let me know if you are able to open it or convert it to dwg.
best regards.
