Getting data using FME REST API
  • Jul 23, 2018 5:22 PM UTC
  • 6 replies
  • 542 views
sashal
Forum|alt.badge.img+13
Hi, I am using the FME Server REST API and needing some guidance.
I have a published workspace in FME Server and run daily via the scheduler to output a .json file on my FME Server. I am trying to call the data with the FME Server REST API to retrieve the .json file so that I can hand it over to our web developer for him to use for an application he wrote. I do not want the FME Server Job to run everytime an API call is made to get the .json file/data.
I am new to using the FME Server REST API but have tried playing around with the API v3 GET GET /repositories/< repository >/items/< item >/datasets/< dtype >
Can someone please help me to get on the right track on using FME server to get my data via an API call/URL?
Thanks!
  • Jul 23, 2018 5:35 PM UTC
As far as I know, best way to achieve this is to write the output data in the FME Server Resources and use the REST resource API to read the json file.
sashal
  • Jul 23, 2018 5:52 PM UTC
Thank you, Larry. I have never done that before... would this be a parameter link to make in my json writer?
siennaatsafe
Forum|alt.badge.img+12
Hi, thank you for posting your question on the community page. From my understanding, you have a workspace that is writing a JSON file to a resource on your FME Server. We do have a call to download files and it is located here: https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/resources/postDownload_post_8
The URL would be: POST resources/connection/<resource>/download/path.
An example of how to use this call can be found here:
REST API Training Course (this page may change as we update the course).
If you get stuck with this please let me know!
Also, in a week we have a full course on the REST API if you are interested. https://www.safe.com/training/registration/7010c000002WjbFAAS/
  • Jul 23, 2018 6:32 PM UTC
The json output path in your workspace must write to a resource folder. As an example, if your write your json file directly to the resource data folder, the path will be:
$(FME_SHAREDRESOURCE_DATA)test.json
Then, your developer can use the REST API this way:
http://fmeserver/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/download/test.json
sashal
  • Jul 24, 2018 7:41 PM UTC
Thank you @SiennaAtSafe All great suggestions! I will check out the training course.
sashal
  • Jul 24, 2018 7:44 PM UTC
We were successful! Thanks @larry & @SiennaAtSafe
Note: It helped me to download Postman for Chrome and test the urls and get requests.
