Georeferenced PDF
  • Mar 21, 2018 8:46 AM UTC
  • 115 views
Hy
I want to know if it is possible to georeferencered the PDF before to use the PDF reader to obtain in the output a DWG or Esri GeoDb with the correct coordinates system
thx
Francesco
stalknecht
Forum|alt.badge.img+22
  • Mar 21, 2018 9:45 AM UTC
The geospatial pdf contains the coordinate system information. You can use the pdf reader and write to another format. So if you leave everything blank the coordinate system will be written into the new format.
jneujens
  • Mar 21, 2018 9:46 AM UTC
Did not really understand what you exactly mean. If you have a geospatial pdf, just read it. It's contents should have a coordinate system. If you do not have a geospatial pdf, it will be difficult.
If you can read your PDF as raster you could use a RasterGeoReferencer?
Still georeferencing can be a messy and manual business if you want it to be very accurate.
jakemolnar
Do you mean that you would like to assign georeferencing points to an existing PDF?
Adobe Acrobat Pro has that capability: https://acrobatusers.com/tutorials/how-create-geospatial-pdf
Or maybe you want to create a PDF with FME? In that case, the PDF writer will embed georeferencing for you, as long as your data has a coordinate system.
  • Mar 24, 2018 12:54 PM UTC
Sorry I know the the pdf is a geopdf the coordinates are present
my problen is that usually the pdf don't contains coordinates
