generate pdf report
  • Nov 20, 2019 2:04 PM UTC
  • 128 views
Hi, I need to create pdf report(as the attached), would you tell me what transformers that I need to use.
the reader is AGOL or sde database. I cannot use HTML2PDFConvertor because we not allow to load WKHTMLTOPDF.exe. thanks a lot
milo89
Forum|alt.badge.img+26
  • Nov 22, 2019 2:28 AM UTC
Hi @knfme2019,
A few questions to see if I can provide some assistance.
Do you currently have the report in PDF format?
From the AGOL reader, is it the attributes of each feature that will be used to populate the fields of the attached sample report?
