gbxml Format
  • May 4, 2015 2:23 PM UTC
  • 107 views
franco69
Forum|alt.badge.img+11
How is the  status to read/write gbxml format in FME?
Best answer by david_r
Green Builing XML doesn't seem to be directly supported: http://www.safe.com/fme/format-search/#search=xml
On the other hand, there are a good number of functions in FME that should make it possible to support the most basic object types without too much effort, I guess.
Some starting points: You might also want to contact Safe support (https://safecommunity.force.com/knowledgeSubmitCase) to see if gbXML support has been planned.
David
  • May 4, 2015 3:43 PM UTC
David
fmelizard
Forum|alt.badge.img+22
  • Apr 2, 2018 10:16 AM UTC
Safe internal PR#28282
deanatsafe
  • Sep 4, 2018 6:22 PM UTC
Take a look at this custom reader posted to FMEHub: https://hub.safe.com/formats/green-building-xml-gbxml
