Format error when using ArcGisOnline
  • Apr 30, 2024 4:23 PM UTC
  • 107 views
scottshenberger
I have an error message: ArcGIS Online Feature Service Writer: Encountered an unexpected error. The error code from the server was '400' and the message was: 'Cannot perform operation. Invalid operation parameters.'. Details: ''deletes' parameter is invalid, Input string was not in a correct format.' ARCGISONLINEFEATURES writer: An error has occurred. Check the logfile above for details
I have checked the log file but honestly I am not sure what I am looking for. Attached is the logfile and my AGOL service format.
Thanks
kailinatsafe
Forum|alt.badge.img+24
Hello @scottshenberger, thanks for posting! Confirming we are updating an existing feature service? Also, can you confirm you have the correct permissions to perform inserts/updates/deletes to the target feature class? For example, are you able to delete records from the feature service directly in AGOL?
It might be beneficial to share a copy of your workspace as well. Happy to help, Kailin.
