fme_text features with empty fme_text_string. Could it be a GEODATABASE_FILE Reader configuration problem?
  • Nov 18, 2023 5:09 PM UTC
  • 6 replies
  • 148 views
jorge_rosales
Forum|alt.badge.img+8
If you execute the attached workspace...
imageYou get fme_text features with empty fme_text_string (but TextString has a value).
imageAny suggestions?
Best answer by redgeographics
Let me rephrase my question: can you show a feature in ArcGIS that has a text string and then that same feature in FME where it does not have a text string?
I don't have ArcGIS, so I can't use the ESRI-version of the Geodatabase reader. However, if I use the OpenAPI Geodatabase reader I can see all points have a TextString attribute (which is not the same as fme_text_string).
So then a LabelPointReplacer to turn them into actual text objects does the trick.
Forum|alt.badge.img+63
Your screenshot shows at least one feature with an fme_text_string so it's probably not a configuration issue. Are you 100% sure all features should have a fme_text_string?
jorge_rosales
  • Nov 20, 2023 8:55 AM UTC
FME recognizes all features as fme_text, so according to the documentation I expected the fme_text_string, fme_text_size and fme_rotation attributes to have values.
jorge_rosales
  • Nov 20, 2023 9:15 AM UTC
Seems. If you open the gdb of the example in ArcGIS you will be able to see the texts. But if you read the annotations with FME, fme_text_string is missing.
jorge_rosales
  • Nov 20, 2023 10:01 AM UTC
Thanks @Hans van der Maarel​. The TextPropertyExtractor transformer seems to fix the problem as well.
