FME Server Login from localhost
  • Jul 14, 2014 7:07 PM UTC
  • 34 views
Is there a way to protect the login page for FME Server 2014? I would like to allow login only from localhost, that is, on the machine itself. You can do stuff like this with Apache. Is it possible with FME Server 2014?
Thanks
Best answer by redgeographics
You should be able to control that through the .htacces file, see the documentation on your webserver for details on how to set that up.
Forum|alt.badge.img+63
