FME Server file extension not specified
  • Jan 30, 2019 5:06 PM UTC
  • 57 views
Hi all,
I have a question concerning the output format of a tool on FME Server.
Tool runs fine: input contans a DEM-layer, output contains a ZIP-folder including a .dwg-file.
There is only one problem: I manually have to add the extension .dwg at the end of the file name, in order to open the file as a .dwg. Right now, the output file has no extension given after extracting the ZIP-folder. After adding .dwg to the file name, the file is correct.
Anyone having a suggestion?
daveatsafe
Forum|alt.badge.img+24
  • Jan 30, 2019 11:08 PM UTC
Hi @martin_fme,
Please check the workspace you are running to ensure that the AutoCAD writer is being supplied an output file name including an extension, especially if a dataset fanout is being used. The writer will not automatically add an extension to the file name.
If you would like to share the workspace with me, I would be happy to have a look at it - .
