FME Server and DWG template files
  • Feb 12, 2013 5:41 PM UTC
  • 105 views
Hello,
I'm working on a solution using FME Server's datadownload service on which I'm trying to write out to a DWG with an uploaded template file (via the datadownload web gui).
Currently it fails with the log error:
Failed to copy template file '\\prototyp.dwg' as the destination file 'C:\\Windows\\TEMP\\FME_1360689826165_4428.dwg'. Error is 'The operation completed successfully.
which is funny because it says it completed successfully but obviously it didn't.
The test case I'm running is just a DWG reader connected to a DWG writer with the writer's template parameter published. If I remove the published parameter and provide the template as a resource the workspace translates successfully.
I've checked the permission on C:/Windows/Temp and even tried with permission to Everyone on full. The FME Server is running on Windows Server 2008 R2.
// Jonas
sigtill
Forum|alt.badge.img+25
  • Feb 13, 2013 10:51 AM UTC
So actually you want to write to the LOCAL filesystem of FME Server, instead of downloading the finished result? Have you looked at this? http://fmepedia.safe.com/articles/Error_Unexpected_Behavior/FME-Server-Workspace-Fails-to-Write-Data
sigtill
  • Feb 14, 2013 4:45 PM UTC
Hm. Perhaps you need to add the FME_SERVER_DIST_DIR before the filename to correctly find the file on the "temp" catalogue of FME Server? More information and links to Scripted Parameters here:
http://fmepedia.safe.com/AnswersQuestionDetail?id=906a0000000cgbiAAA
