FME doesn't detest postgres insert errors
  • Jan 28, 2019 8:32 PM UTC
  • 39 views
I use FeatureWriters in FME Workbench 2017 for inserting datasets in Postgres.
But when there are errors in my input data, like a string instead a boolean value, the row is not written in Postgres but FME doesn't detect the error, the row is counted like a correct insert and I have the message "Translation was successfull" at the end.
Of course, I could use AttributeValidators to detect such errors but I have a lot of fields and I wouldd like to avoid to inspect each field.
Thanks in advance for any help,
Christian
Best answer by david_r
Have a look at my answer here: https://knowledge.safe.com/questions/78899/can-i-force-a-translation-to-fail-if-violation-of.html
  • Jan 29, 2019 8:13 AM UTC
  • Jan 29, 2019 11:38 AM UTC
Tnak you David, very interesting, I'll give it a try !
