FME DESKTOP crashes intermittently when reading MS Excel features
  • Jul 18, 2016 10:43 AM UTC
  • 47 views
andrew_patterso
Forum|alt.badge.img+3
Hello All,
This applies to FME 2013 Oracle Edition (2013 - Build 13263 - WIN 32). One of the scripts we run intermittently fails. This happens when reading an excel file
Trying to find a DYNAMIC plugin for reader named `XLS_ADO' Loaded module 'XLS_ADO' from file 'D:\\Program Files (x86)\\FME\\plugins/FME_ADO.dll' FME API version of module 'XLS_ADO' matches current internal version (3.7 20121025) MS Excel Reader: Read 1 DEF line(s). Found 26 attribute(s) MS Excel Reader: Opening `[Filepath]' for read operation MS Excel Reader: Verifying registry key HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Jet\\4.0\\Engines\\Excel\\TypeGuessRows is of type 'REG_DWORD' and has a value of '0' MS Excel Reader: Registry value 'HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Jet\\4.0\\Engines\\Excel\\TypeGuessRows' expected to have data of '0', but found '8' MS Excel Reader: Verifying registry key HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Jet\\4.0\\Engines\\Excel\\ImportMixedTypes is of type 'REG_SZ' and has a value of 'Text' MS Excel Reader: Temporarily patching Excel registry for provider 'Microsoft.Jet.OLEDB.4.0'. This change will not be visible to other processes
MS Excel Reader: Now reading features from table Sheet1, 10 record(s) at a time
Reading source feature # 2500
Reading source feature # 5000
This was where FME crashed but then has run successfully afterwards
Would anyone know the cause of this error?
Regards
Andrew
andrew_patterso
This is the log file for when excel file is read successfully
Trying to find a DYNAMIC plugin for reader named `XLS_ADO' Loaded module 'XLS_ADO' from file 'D:\\Program Files (x86)\\FME\\plugins/FME_ADO.dll' FME API version of module 'XLS_ADO' matches current internal version (3.7 20121025) MS Excel Reader: Read 1 DEF line(s). Found 26 attribute(s) MS Excel Reader: Opening `[Filepath]' for read operation MS Excel Reader: Verifying registry key HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Jet\\4.0\\Engines\\Excel\\TypeGuessRows is of type 'REG_DWORD' and has a value of '0' MS Excel Reader: Registry value 'HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Jet\\4.0\\Engines\\Excel\\TypeGuessRows' expected to have data of '0', but found '8' MS Excel Reader: Verifying registry key HKEY_LOCAL_MACHINE\\SOFTWARE\\Wow6432Node\\Microsoft\\Jet\\4.0\\Engines\\Excel\\ImportMixedTypes is of type 'REG_SZ' and has a value of 'Text' MS Excel Reader: Temporarily patching Excel registry for provider 'Microsoft.Jet.OLEDB.4.0'. This change will not be visible to other processes MS Excel Reader: Now reading features from table Sheet1, 10 record(s) at a time Reading source feature # 2500 Reading source feature # 5000 Reading source feature # 7500 Reading source feature # 10000 MS Excel Reader: Database read complete. Retrieved 11226 feature(s) MS Excel Reader: Closing `[Filepath]' . Read operation complete
