FME 2018 FMW reader Parameter value SQL_STATEMENT format
mferwerda1111
Participant
In FME 2018 when reading out the SQL_STATEMENT from the Transformer Parameters reader, the SQL comes out formatted roughout like this example:
SELECT<space><lf>SITE_ID_FS<comma><lf>LIFEFORM<comma><lf>PLANT_CODE<comma>
<space><space><space><space><space><space><space>from<space>my_table<lf><space>
where <space> LIFEFORM <space>= <space><apos>TR<apos>
Is there an easy way to decode this back to a simple text that will run again in a SQL window ?
It looks like FME 2019 handles this better, but I am limited to 2018 for now.
  • June 19, 2019
Try the following in a PythonCaller:
import fmeobjects
def decode_fme_encoded_string(feature):
    text = feature.getAttribute('sql')
    if text:
        decoded = fmeobjects.FMESession().decodeFromFMEParsableText(text)
        feature.setAttribute('sql', decoded)
Assuming that the attribute name is 'sql'.
mferwerda1111
Participant
  • Participant
  • June 19, 2019
Thanks,much appreciated
