Fill in adjacent empty values in table is not working as I expect?
norris
Forum|alt.badge.img+3
I am trying to fill in the rows of my table with the previous values. I saw this thread and I am following the instructions but for some reason I am only getting the first empty row to be filled but not any subsequent rows.
I tried to change the Subsequent Features to another value other than 0 and even tried to change the number of Prior Features but I always get the same results.
I am on FME Form 2024.2.0.0 if that helps.
Any suggestions as to what I am doing wrong?
Best answer by takashi
Hi ​@norris ,
If I understand your requirement correctly, I think this setting  works as expected.
crutledge
Forum|alt.badge.img+32
  • May 9, 2025
Hi ​@norris From what I see, if you are trying to fill the <nulls> in the “test” column you could replace .fastigeter with .test
The way I read the example you have the red lines are what is being written from Fastigheter to test
Hope that helps.
tomfriedl
Forum|alt.badge.img+13
  • May 9, 2025
The workbench does what you have defined.
I think,
else   feature[-1].test
delivers the desired result.
norris
  • May 9, 2025
Thanks for the suggestions ​@crutledge and ​@tomfriedl
Apologies for not being clear in my original post. The screenshot to the right (in my original post) is what i get as a result from the AttributeCreator as I created a new column called “test” in the AttributeCreator. The “input” is the column “Fastigheter” and what i want is the column “test” to contain the filled row values.
Here is what the input table looks like (just dummy to test things)
here is what I wanted to do with AttributeCreator (but did with Python)
I did manage to get my desired result with pythoncaller but it would be nice to know how to get it to work using a transformer.
here is my python caller code if anyone was interested
class FeatureProcessor(object):
    def __init__(self):
        # Store the previous non-empty value
        self.previous_value = None
    def input(self, feature):
        # Get the current value of the 'Fastigheter' attribute
        current_value = feature.getAttribute('Fastigheter')
        # Check if the value is empty or None
        if current_value is None or current_value == '':
            # If empty, use the previous non-empty value (if available)
            if self.previous_value is not None:
                feature.setAttribute('Fastigheter', self.previous_value)
        else:
            # If not empty, update previous_value
            self.previous_value = current_value
        # Output the feature
        self.pyoutput(feature)
    def close(self):
        pass
  • May 9, 2025
Hi ​@norris ,
norris
  • May 9, 2025
Thank you so much ​@takashi This worked perfectly!
