Excel Fill Down Function
  • February 19, 2020
  • 91 views
Hello Friends,
I need an urgent help. Can anyone please help?
I am having something like this:
and i want to fill down the values something like this in excel:
its like a fill down option for sample id and ID till the time it finds a new sample line in text_line data or till the time it finds a blank value in its own column and stop when next row has a value.
Also attaching the excel file for your reference.
Thanks
Best answer by ebygomm
Yes, you can do this in an Attribute Creator using adjacent feature attribute handling and a conditional formula. So this looks at whether Sample ID has a value and if it does then the value remains as is, otherwise it is set to the Sample ID of the previous feature
Forum|alt.badge.img+39
  • February 19, 2020
You are a life saver!! Thanks a ton
