I am running a simple read GDB Write GDB and adding a UUID in the process. I am getting this Error (-3). The source is a 3D line file 60K lines long and has four fields. (survey data). I've rerun the script several times and the error halts writing at different locations in the file.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
