FileGDB Writer - Geodatabase Error (-3)
  • Apr 16, 2018 3:13 PM UTC
  • 45 views
I am running a simple read GDB Write GDB and adding a UUID in the process. I am getting this Error (-3). The source is a 3D line file 60K lines long and has four fields. (survey data). I've rerun the script several times and the error halts writing at different locations in the file.
erik_jan
Forum|alt.badge.img+26
  • Apr 16, 2018 3:18 PM UTC
Is the destination also set to 3D lines?
If not, vertical line segments will cause duplicate points on the line, causing the Geodatabase to reject those features.
