File geodatabase reader not reading an annotation layer created in ArcGIS Pro.
  • Jul 19, 2018 9:46 PM UTC
  • 160 views
I attempt to add a file geodatabase reader for this database (D:\\Workspaces\\My FME Workspaces\\Support\\AnnoFClassError\\CompetitorLeasesArcGISPro.gdb\\CompetitorLeases) and I get the following error: |WARN |Unable to read from the table/feature class 'CompetitorLeases_Anno'. If 'CompetitorLeases_Anno' contains a class extension, make sure it is registered on this computer. A reader is added, but no featureclass.
The annotation layer was created by ArcGIS Pro 2.2, but I'm using FME 2018.1 and the email I received today claimed that the ArcGIS Readers/Writers are upgraded for ArcGIS Pro 2.2.
Has anyone else experienced this and have a suggestion?
xiaomengatsafe
Forum|alt.badge.img+11
Hi @deanrother, The team is working on reading ArcGIS Pro annotations right now. This will appear in an FME 2019 beta at some point. We will add an update here, when that's available. There is a related question, in case you are curious.
  • Mar 27, 2019 2:06 PM UTC
Hi @xiaomengatsafe . Has this functionality made its way into the current FME 2019 Release Candidate?
andreaatsafe
Forum|alt.badge.img+17
Hi @jclough, Please see the related question about the updates on this functionality.
trentatsafe
Forum|alt.badge.img+7
Hello @deanrother and @jclough,
ArcGIS Pro Annotation reading is now supported in FME 2020.0 B20161+. You can find the FME 2020.0 beta here: https://www.safe.com/support/downloads/#beta
As it stands we currently only support Reading ArcGIS Pro Annotation, if you would like to see Writing ArcGIS Pro Annotations as well, please let us know.
