FeatureReader Parameters
  • Oct 10, 2017 12:10 PM UTC
  • 5 replies
  • 184 views
bjudes
Forum|alt.badge.img+10
I have multiple jpegs in multiple folders. I first read in using the Directory and File pathnames reader. I didn't want all jpegs to be read so I created a tester to negate some of these. Next I used a string searcher to isolate only the jpgs and not world files or .aux. Next is where my issue arises. I want to now read in the jpgs that I have isolated using a FeatureReader. But within the feature reader parameters for dataset I don't know how to link back to the jpeg files. Any ideas would be greatly appreciated.
Thanks
Best answer by david_r
Here's how I'd set up the FeatureReader to point to the "path_windows" attribute supplied by the Path names reader:
Notice that I'd also choose to use a single output port, this simplifies your workspace slightly as every jpeg is then output from the <Generic> output port:
  • Oct 10, 2017 12:19 PM UTC
What value are you passing as "Dataset" in the FeatureReader? Perhaps send the output from the StringSearcher to a Logger so you can see what's going on. From the Path names reader you probably want to use the "path_windows" attribute.
Rather than using the StringSearcher, you can tell the Path names reader to only return .jpg files:
bjudes
  • Oct 10, 2017 12:31 PM UTC
That's my problem, I'm not sure what to add as "Dataset" in the FeatureReader. I want to link this to the jpegs that have been isolated in the multiple folders that have been read through the intital Directory and File Pathnames reader.
bjudes
  • Oct 10, 2017 12:36 PM UTC
translationlog.txt
bjudes
  • Oct 10, 2017 12:44 PM UTC
That worked perfect.You're a genius!! Thanks so much for the swift help.
