FBX converted from CityGML can`t open in Blender
  • Aug 17, 2017 2:13 PM UTC
  • 123 views
I have a cityGML file.
I added the FBX writer and used the Generate option to convert it to FBX.
It generates without errors 6 files, but if I try to open them in Blender I receive an error related to the incorrect binary. The same with every 3D modeling editor: can´t open it!
Someone can help me? Screenshot available below. If needed, I can paste the log file.
fmelizard
Forum|alt.badge.img+22
  • Aug 17, 2017 11:04 PM UTC
Hi @style have you experimented with any of the other output types? I'm not familiar with Blender but it might be that the default output format isn't supported in Blender.
fmelizard
Hi @style
you get Blender error when you attempt to import FBX, am I correct? What other formats have you tried? Have you tried OBJ?
  • Aug 18, 2017 7:26 AM UTC
Have you tried Autodesk FBX Review? https://www.autodesk.com/products/fbx/fbx-review
FBX is a format designed by Autodesk, so I think you can consider the FBX dataset is fine if the FBX Review can open it correctly.
