Failed to write to file error
  • July 3, 2024
  • 128 views
cpedron
The last few weeks I have been getting an error message whenever I try to frequently run my workspaces. Since I am testing transformers, and attempting to find the ones that create the most appropriate outputs for my task, which is converting a shapefile to match with a preset schema. If I run the full workbench and then change something because the output did not match what I needed, then run the workbench again. I get an error that says “Failed to write to file” with the file path pointing towards a .dbf filetype in my output folder. The only fix at the moment is completely closing FME and reopening. But doing this for every small iteration is not feasible long term.
Best answer by mark2atsafe
That sounds very odd. I suggest you go straight to the support team with that one. See safe.com/support and use the Submit Ticket option.
mark2atsafe
Forum|alt.badge.img+49
  • July 3, 2024
