extracting information from different folders in KML to convert to the shapefile
gis2020
Forum|alt.badge.img+5
Hi All,
I have a KML data which has many folder . Each folder is having different set of geometry eg route1 ,route 2 with other attributes . also each folder has unique number which i want to link to route information . herewith i have attached the screen shot of the KML highlighting the information which i am trying to fetch . Also attaching the KML file .
Things i have tried :
i mange to do the geometry extraction with KML description for each route but unable to link the route to the folder number .
Any suggestion on this ?
Thank you in advance.
danilo_fme
Forum|alt.badge.img+47
  • August 21, 2020
Hi @gis2020​
I exposed into your Reader the format attribute kml_name.
I used too the transformer HTMLToXHTMLConverter for extract description.
The transformer TesterFilter was used for separate the kml_name:
  • Route1
  • Route2
  • Others
Thanks in Advance,
Danilo
danilo_fme
  • August 21, 2020
danilo_fme wrote:
Hi @gis2020​
  • Route1
  • Route2
  • Others
Thanks in Advance,
Danilo
Workspace_KML
nielsgerrits
Forum|alt.badge.img+56
The Features with featuretype Folder have the attributes kml_id and kml_parent.
You can see those in the Inspector when you select a feature and check the Feature Information window. Use an AttributeExposer to expose them. .
With these attributes you should be able to rebuild the folder structure.
gis2020
  • August 21, 2020
danilo_fme wrote:
Workspace_KML
Image 4@danilo_fme​ i have tried this but this doen't give me the folder name/number for routes .
gis2020
  • August 21, 2020
@nielsgerrits​ i have tried this option also but there is definite link between the folder and routes . as KML_id are different for each description line .
eg kml_id_batch_b_1_IDN_1.1.13 for folder and kml_id_batch_b_1_IDN_1.1.13.3 and kml_id_batch_b_1_IDN_1.1.13.4 for routes . Also there is no consistency of numbering.
nielsgerrits
  • Folder "515552200" has id kml_id_batch_2_1.1.13 and parent kml_id_batch_2_1.1
  • Folder "Route1" has id kml_id_batch_2_1.1.13.3 and parent kml_id_batch_2_1.1.13
  • Placemark "Route1" has id kml_2 and parent kml_id_batch_2_1.1.13.3 and kml_description POS=0 DL=0 NEG=21 DL=20
The numbering is structured by points. Every point is a level deeper.
What I would do:
  • Determine the max number of levels.
  • Use BulkAttributeRenamers to add prefixes like Level1,Level2,etc to the attributenames. (Split features using the number of points in each id.)
  • User FeatureMergers to add the parent to each child, starting with the deepest level and work you way up.
gis2020
  • August 21, 2020
@nielsgerrits​ that's what exactly i am doing now . i am extracting the parent from the child eg 2_1.1.13 and then i am going to match it with folder parent.
