Extract json from json string
  • Apr 27, 2020 12:55 PM UTC
  • 190 views
nedwaterman
Forum|alt.badge.img+9
I'm trying to extract attributes from the attached json string using a jsonextractor.
I thought the jsonquery field would be json["datetime"] but nothing is being returned.
Any help is gratefully received.
Thanks
N
Best answer by ebygomm
Assuming you want to get multiple features from this, I would use the JSONFragmenter with the following query
json[*] ["datetime"]
Forum|alt.badge.img+54
  • Apr 27, 2020 1:22 PM UTC
nedwaterman
  • Apr 27, 2020 1:24 PM UTC
Cheers - I did finally figure this out through some judicious goggling (after the event!).
Thank you!
  • Apr 27, 2020 1:31 PM UTC
Thank you!
If you want all the parts as attribute values I'd use these settings though
nedwaterman
  • Apr 27, 2020 1:32 PM UTC
Cheers!
