Extra forward slashes in FME SHAREDRESOURCE DATA path
  • November 30, 2017
  • 41 views
I am trying to automate an ESRI Enterprise Geodatabase Compress with FME Server. The problem I have run into is with using the Server Parameter FME_SHAREDRESOURCE_DATA I have stored my SDE connection files in a folder there. When the workspace replaces the variable with the path to my FME Data Resource it is including two extra slashes / between the FME Server folder and the resources folder like this ...FME Server///resources/data/ I know I can fix this by replacing that in the workspace or hard coding the path rather than using the variable, but I'm wondering if there is a way to fix this so I can use the system variable straight up?
I solved my problem. I found that the paths recorded in the fmeEngineConfig.txt and fmeServerConfig.txt contained the extra spaces. I fixed the paths there, and re-started FME Server to fix this issue.
