Expose value Python Caller
  • October 20, 2024
  • 46 views
mr_fme
Forum|alt.badge.img+9
How can I expose the result (print), like attribute in python caller:
        from_value = min_iten[0]['from']
        to_value = min_iten[0]['to']
        print(f"{from_value[:-10]}")
Thank´s
Best answer by hkingsbury
You need to use the setAttribute() function on the feature object, then set that new attribute to be exposed.
Your input function should therefore look like:
    def input(self, feature: fmeobjects.FMEFeature):
        """This method is called for each feature which enters the PythonCaller.
        Processed input features can be emitted from this method using self.pyoutput().
        If knowledge of all input features is required for processing, then input features should be
        cached to a list instance variable and processed using group processing or in the close() method.
        feature.setAttribute('attributeName',f"{from_value[:-10]}")
        self.pyoutput(feature)
And at the bottom of the PythonCaller, expose your attribute like so:
hkingsbury
Forum|alt.badge.img+56
  • October 20, 2024
mr_fme
  • October 21, 2024
Thank´s @hkingsbury
