Explode hatch
  • Mar 31, 2017 1:22 PM UTC
  • 71 views
zzupljanin
Forum|alt.badge.img+5
this might be odd question but here it goes:
Is it possible to explode hatch paterns to its geometries. For example, if some polygon is hatched with horizontal lines can I get those lines?
Thank you.
itay
Forum|alt.badge.img+19
  • Mar 31, 2017 1:38 PM UTC
Try the deaggregator transformer.
zzupljanin
  • Mar 31, 2017 1:44 PM UTC
Nothing happens. There should be 10+ diagonal lines for this particular feature.
  • Mar 31, 2017 2:22 PM UTC
Looks like your hatch is a reference to a pattern called "ANSI31" that is defined in an external .pat file and not stored in your drawing. That's why you don't see it in the Inspector.
You can find the definition of the ANSI31 hatch pattern here:
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-A6F2E6FF-1717-44B6-A476-0CA817ADD77E
It should be possible to re-create it as lines in FME and then clip it using your polygons.
