Exclude wildcard on reader
  • Feb 19, 2018 8:54 PM UTC
  • 116 views
jdh
Forum|alt.badge.img+41
I have two files in a common directory with the following naming scheme
{Know prefix}_{variable suffix}
{Know prefix}_{known infix}_{variable suffix}
ex.
ABC_123
ABC_XYZ_123
Is there an easy way to read in only the file without the infix? The standard wildcard {prefix}* will pick up both files. Currently I'm testing the fme feature type to see whether or not it contains the infix, but ideally I would like to not even read it in.
fmelizard
Forum|alt.badge.img+22
  • Feb 20, 2018 12:06 AM UTC
Heya @jdh,
Excellent question - Just thinking about a workaround which popped into my head, while it's inconvenient Would the PATH reader followed by FeatureReader be an option here for you?
  • Feb 20, 2018 8:31 AM UTC
Why not use a regular expression? (Filter Type: Regular Expression)
^[^_]+_[^_]+$
jdh
  • Feb 20, 2018 3:04 PM UTC
^[^_]+_[^_]+$
My understanding is the Merge Filter is applied after the dataset is read (discarding features that don't match the filter expression),  I'm looking to completely avoid reading in the data.
  • Feb 20, 2018 3:12 PM UTC
^[^_]+_[^_]+$
I think that there is no way to do that in the current FME. I would use the PATH reader, a filter transformer and a FeatureReader, as @MattAtSafe suggested.
