Excel writer: Has anyone noticed that when you specify the sheet name with an attribute the hyperlinks in the excel file no longer work in the latest version!.
  • May 18, 2018 6:08 PM UTC
  • 86 views
If I leave it as sheet 1 all the hyperlinks work. I have multiple sheets that I will add to the excel file so this function should work fine and has in the past version. Could someone help?
Best answer by debbiatsafe
Hi @karlos86
I'm sorry you ran into this issue. This bug was reported internally as PR83486 and have been fixed in FME 2018.1 beta builds 18477 and above. Would you be able to try FME 2018.1?
debbiatsafe
Forum|alt.badge.img+24
  • May 18, 2018 7:03 PM UTC
Hi @karlos86
  • May 22, 2018 6:56 AM UTC
Hi @debbiatsafe
Thanks for your help.  You are correct and this was resolved when I installed the 2018.1 beta version.
Thanks
