Excel writer creating XML errors
  • Jun 27, 2017 1:30 AM UTC
  • 163 views
jordiew
Participant
I'm using FME Desktop 2017.0.1.1.
I have a csv file that I need to merge with 6 different csv files. The 6 different csv files are derived from MapInfo table that Intersects with another table and the selection is exported as a csv.
I have AttributeManager, AttributeCreater, DateFormater and FeatureMerger for each csv. These csv files are FeatureMerger with another csv and the writer is a 6 sheet excel workbook.
When "Translation was SUCCESSFUL with 0 warning(s) (81575 feature(s) output" the excel xlsx file contains errors:
"Removed Part: /xl/sharedStrings.xml part with XML error.  (Strings) Unexpected end of input. Line 1, column 1614248.
Replaced Part: /xl/worksheets/sheet1.xml part with XML error.  Unexpected end of input. Line 1, column 1614250.
Replaced Part: /xl/worksheets/sheet2.xml part with XML error.  Unexpected end of input. Line 1, column 1614250.
Replaced Part: /xl/worksheets/sheet3.xml part with XML error.  Unexpected end of input. Line 1, column 1614250.
Replaced Part: /xl/worksheets/sheet4.xml part with XML error.  Unexpected end of input. Line 1, column 1614250.
Replaced Part: /xl/worksheets/sheet5.xml part with XML error.  Unexpected end of input. Line 1, column 1614250.
Replaced Part: /xl/worksheets/sheet6.xml part with XML error.  Unexpected end of input. Line 1, column 1614250."
Is there some settings in the Navigator that need to be adjusted or do I need to do something else?
jneujens
  • Jun 27, 2017 8:22 AM UTC
Could you give us a screenshot of your workspace? The description of your problem is unclear to me...
mark2atsafe
Forum|alt.badge.img+59
The only reference to that error message ("part with XML error") that I can find is for when an Excel reader/writer is updated (ref PR#47142). It was an older FME, so I don't think it really applies here, but I still think a good solution would be to delete your writer and re-add it. If the problem still occurs, then let us know. Ideally include your workspace and a sample of the bad Excel dataset. That way I can give them to our developers to analyze.
Regards
Mark
