Evaluate Boolean True or False using tester
  • February 6, 2019
  • 5 replies
  • 329 views
miquelrs
Forum|alt.badge.img+7
Here's a basic one. Have a Boolean field and need to evaluate if it is T or F using a Tester transformer.
Have tried using "Field = F", "Field = False", "Field = 0" in the tester, but none of them seem to work.
This should be straightforward but I can't find it anywhere in the documentation.
Thanks in advance,
Best answer by david_r
It will depend on the input format. In my experience boolean fields are often represented as lower-case "true" or "false", but it can vary.
If you're completely stuck, consider connecting an Inspector on the reader (or create a breakpoint) and look at the data.
  • February 6, 2019
miquelrs
  • February 6, 2019
Thanks david_r, I have already inspected the field and seems to be string "false", but using "false" in the tester doesn't work.
  • February 6, 2019
Can you post a screenshot of your Tester configuration?
miquelrs
  • February 6, 2019
It worked now using Filed = false. I needed to delete the output before running the script, otherwise it was just adding rows at the end of the existing file.
Thank you very much!
  • February 6, 2019
Excellent!
