Esrishape format
  • Nov 5, 2013 1:25 AM UTC
  • 41 views
I have a doubt, Would it be possible to obtain the name of EsriShape file as an attribute of his reader?
Thanks
  • Nov 5, 2013 1:49 AM UTC
In ESRI Shape format, the format attribute named fme_basename or fme_feature_type will be same as the source file name without extension,  and fme_dataset will be the full path.
You can expose them on the Feature Type Properties dialog box of the reader, or using the AttributeExposer transformer.
Takashi
fmelizard
Forum|alt.badge.img+22
  • Nov 5, 2013 8:13 AM UTC
You can also make use of the FeatureTypeExtractor transformer.
Itay
  • Nov 9, 2013 5:18 PM UTC
Thanks!!!
