Error was 'ERROR: value too long for type character varying(50)
  • August 26, 2022
  • 513 views
Good morning,
I’m trying to transfer data from ESRI to PostGis.
Unfortunately, I encounter the following error:
I understand that the created field is too short but I can’t change it...
Thank you for your help.
tomfriedl
Forum|alt.badge.img+13
  • August 26, 2022
"but I can’t change it..."
so you must shorten the string with the SubstringExtractor.
  • August 29, 2022
@renaud_nm​ I agree with @tomfriedl​ . You'll have to isolate the long text strings by testing the length > 50 and then try and find a pattern to shorten them. Either remove spaces or other none word characters.
