"Error running translation" after what appears to be a successful write to an ArcSDE feature class.
  • Aug 20, 2018 4:46 PM UTC
  • 132 views
bo
Forum|alt.badge.img+10
There are a plethora of discussions on the "Error running translation" error, but none seem relevant to my simple workflow, as shown in the attached image, that writes a simple point geometry to an ArcSDE layer. The error msg was misleading as the point had been successfully written.
I turned on the debug log and found a "BADNEWS" error in the log - - which I was not sure of its relevancy.
nathanatsafe
Forum|alt.badge.img+9
Hi @bo, thanks for your post!
This was a common issue earlier in the year, but since you are running FME 64-bit, with ESRI background geoprocessing, on Windows 7, you might be a candidate for this issue and the associated patches from ESRI which fix the issue.
One quick litmus test for the above would be to test your workspace using FME 32-bit. If it runs successfully, there's a really good chance you need the patch linked above.
Hope this helps! Let us know if it doesn't :))
Nathan
bo
  • Aug 20, 2018 5:45 PM UTC
Nathan
Thanks, @nathanatsafe! We will look into this and confirm.
ostoja
  • Feb 21, 2019 9:49 AM UTC
Hi @bo,
I am having the same issue here.
Writing in the versioned table is complete, but on the end of the log I get this strange message "Error running translation". Issue is that in the process which I am using, workbench is called from .bat file and the call returns code -2146234327 and not 0 as expected.
I am using 32-bit FME 2018.0.
Did you maybe find the reason for this issue?
Dušan
xiaomengatsafe
Forum|alt.badge.img+11
Hi @bo,
Dušan
Hi @ostoja,
Thanks for posting your question. Since you are using 32-bit, while bo was using 64-bit, I suspect the cause of the problem might not be exactly the same.
You might get more fitting suggestions, if you can post your specific problem in as a separate New Question, and provide relevant details such as your workspace, and full log file. Thank you!
Best regards, Xiaomeng
