Error reading geopackage
  • Dec 4, 2020 8:02 AM UTC
  • 513 views
r_huesken
Forum|alt.badge.img+5
I have troubles opening the attached geopackage, and I can't figure out what is wrong with it. It opens nicely in QGIS (where it displays the rasters) and with a SQLite client I'm able to access the tables.
The error is : "OGCGEOPACKAGE reader: `IHC Krimpen online - Progress - GRD - Version 1_20200409 204806.gpkg' exists but could not be opened. File contents may be invalid, or the file format may not be supported
Using FME 2020.1
Best answer by nielsgerrits
This works for me in 2020.2.
Please make sure you use the correct reader, not OGC GeoPackage but OGC GeoPackage Tiles.
FeatureReader ParametersDataInspector
nielsgerrits
Forum|alt.badge.img+67
r_huesken
  • Dec 4, 2020 9:15 AM UTC
I did an additional investigation, and noticed that the table and layer names contain a - (minus). This causes some issues. However, renaming the tables and layer data does not resolve the FME errors upon opening this file.
r_huesken
  • Dec 4, 2020 9:19 AM UTC
Thanx, also works for me with 2020.1
