Enable user to select which dataset to read
  • May 15, 2020 11:23 PM UTC
  • 91 views
damian6105
Participant
Dear FME Community
I have 70 different species datasets - Species 1, Species 2, Species 3, ..., Species 70. Each dataset is stored in ArcGIS Online. I want to write each dataset to Shapefile. I am trying to create a reader / parameter that will enable me to pick a single species to write to shapefile when I run the FME script. Can anyone assist please?
The ArcGIS Online reader requires the following parameters for each species:
Feature Service : MyFolder/Species 1/Species 1_WFL
Layer: Species_1
Regards, Damian
Best answer by erik_jan
This can be done using Published parameters (in your case a Choice or Choice with Alias).
These articles give a good overview what to do with Published Parameters:
https://knowledge.safe.com/articles/1287/published-parameter-examples.html
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_DataInspector/Workbench/Running_a_Workspace_with_Published_Parameters.htm
https://knowledge.safe.com/articles/920/concatenating-or-combining-published-parameters.html
Hope this helps getting started.
erik_jan
Forum|alt.badge.img+26
  • May 15, 2020 11:52 PM UTC
damian6105
Participant
  • Participant
  • May 16, 2020 12:02 PM UTC
Thanks @erik_jan. I figured out a solution. For the benifit of other newbs like me I created two published parameters (choice with alias), one for my feature service, one for my layer. Using a Feature Reader transformer, I put the feature service parameter in 'Feature Service' field and my layer parameter into "Feature types to read' field. I then connected my shape file writer to 'Generic' output port of the Feature Reader transformer.
Cheers, Damian
