editing csv schema once created
  • Apr 28, 2016 2:37 PM UTC
  • 82 views
I create a CSV and define the schema at creation. if I modify the csv, I cannot go back and edit the fields (add or rename) as all of them are grayed out, I can only delete and recreate the reader to do this update.. is there a way to edit the csv reader once created? thanks!
  • Apr 28, 2016 3:06 PM UTC
Hi
You can activate the modification of reader attributes under Tools / FME Options / Workbench / Allow reader feature type editing.
Having said that, it is usually both quicker and safer to just use the Readers / Update feature types menu item.
David
gio
Forum|alt.badge.img+15
  • Apr 28, 2016 3:07 PM UTC
i think you can use
Readers=>UpdateFeatureTypes (menu item)
