ECW writer compression
  • Mar 5, 2020 1:56 AM UTC
  • 159 views
nicholas
Forum|alt.badge.img+14
I am transitioning from using ERDAS Imagine to FME to generate ECW files
I need to understand the difference between the terminology used by both systems with regards to compression.
FME ECW writer refers to "Compress by Percentage (0-99)" with a default of 75
this means that the output image will be 75% compressed, or one-quarter the size
ERDAS Imagine refers to "Target ECW Compression" with a default of 20
this means that the output image will be compressed by a ratio of 20:1, or one-twentieth the size.
Two questions;
1) Why does FME use a compression percentage and not a compression ratio (the convention established by ERDAS)
2) Why is FME's default compression different to ERDAS's default compression?
jovitaatsafe
Forum|alt.badge.img+11
Hi @nicholas,
We use compression percentage due to the programming libraries that we're using for ECW, in particular this parameter phrasing comes from GDAL. I suspect that the differences in default compression would also be attributed to the different libraries that we're using to the ones that ERDAS uses.
It might be worth posting a new Idea here if you wish to see changes in the compression method from the user side of things so that it's a more consistent experience when working with raster compression.
