Dynamic update user param
  • Oct 28, 2024 11:38 AM UTC
  • 620 views
kanhan1
I want to fill the User Param Choice with data from a table in MS SQL. This works fine with the 'Import->From dataset...' option. but this function only populates data statically. Is there any way to 'hack' this to fetch data dynamically? The idea is that this Workspace should work in a App in FME Flow.
emma.at.safe
Forum|alt.badge.img+11
Hi @kanhan1,
You might find it helpful to look into Scripted Selection. This feature is available in FME version 2024.0 and later. This parameter type allows users to select from a dynamic list of options based on a Python callback. You can read more about it here:
Hope this helps!
Emma
kanhan1
  • Nov 5, 2024 11:07 AM UTC
Hi, Emma.
Thank you for your reply. Will look a little closer at this option. Does Safe plan to create a suitable function for this in the future?
Hans Ove
